メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
モデル A1136 / 30GB、60GB、または80GBハードドライブ / ブラックまたはホワイトのプラスチック製フロントパネル
iPod won't charge
I bought a used Ipod Classic 5 about two months ago. The seller put a new battery in as well. I have been using it fine for about two months now. Charging via wall and/or computer worked fine. I haven't used it for about two weeks now and the last time I used it I did until the battery was completely drained.
I went to charge it on my wall outlet now and it wouldn't show any signs of life.
I waited a good 2 hours and still nothing happened.
Whenever I tried turning it on, it would just show the apple logo for a brief second and then shut off again.
Something weird to note is that after nothing happening via wall charge I tried charging it on my computer and when I plugged it in I got a windows notification for a USB power surge, telling me to immediately remove the device from USB because it was drawing too much power.
What could be happening? And how do I fix it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Replace the battery. The battery the seller replaced it with is probably a low quality cheap one.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
It looks like you can get the full Fix Kit from iFixit for $19 USD
さんによる 共有
コメントを追加
Try use Firewire if you can, if it shoots into life, which it should as it gives much more power and it lets iPods with even a basically dead battery to turn on, it is probably the battery that is the issue as it may be a low-quallity one.
iPod 第5世代(ビデオ) バッテリーの交換
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Pazulay さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 5
過去 30 日: 17
今までの合計 135
