メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
Touchscreen unresponsive from time to time
Hello,
Sometimes my touchscreen is unresponsive while using the phone. When it happens, I have to lock it and unlock it. Sometimes, when locked, the touchscreen doesn't answer too. So I have to leave the phone alone for a few minutes and try again later.
I have tried:
  • Restarting the phone with Home+Power buttons (10s)
  • Restoring the phone
Others symptoms:
  • I have read that the touchscreen connector could be lightly disconnected. But this problem happens either I use the phone in my hand or placed on a table.
  • I made some tests using the calculator app. When the problem occurs, the gyroscope still works since I can flip the phone and use the calc in portrait/landscape mode.
  • All the buttons (volume, power, home, even handfree kit) works too
Of course, the phone fell down a few times but nothing harmful.
How can I test either it's an iOS or hardware issue ?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 6
コメントを追加
8件の回答
ベストアンサー
Looks like you got a dud touch-screen on your unit. There's nothing you'll be able to do to get it working without voiding the warranty on the unit.
My advice is to take it back to the place of purchase for an instant swap over. Don't let them take it into a 'repair' process, as you are entitled to an instant swap over within the first 10 days from your invoiced date.
Hope this helps
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
I think my warranty period is over.
I bought the phone 18 months ago. This problem first occured after 1 year and then reappears randomly for a few days.
I don't know if I should procede to a screen replacement now or wait and run some more tests (SW solutions) ?
さんによる
Same here. Apple wanted to charge me 320 dollars for a swap sawing it was an issue with a bent frame (the frame is straight as an arrow!). The local cbr shop tried a mil reflow which cured the phone for three hours. This is just a ridiculous hardware or design issue. Does anybody has a fix?
Thanks
さんによる
コメントを追加
This tutorial helped me to fix unresponsive screen on my iPhone 6.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Hi guys I am also getting my iPhone freeze some time and my touch become slow. Really guys I am in trouble now for sort out I use to do press power off. Utton and start again do u have any idea guys
さんによる
コメントを追加
Did you ever get this worked out?
Have you checked to make sure you have at least 10% free storage space on your device? Clear out the multitasker as well. New iOS updates have been known to give legacy devices problems.
Apple says that multitasking doesn't affect performance, I beg to differ. All of my iDevices are Jailbroken and when I clear the Multitask bar, I can watch my available memory jump up.
A dud screen will have consistent dead spots. Usually the same spot in every app and screen. If it is just taking a year(iphone time) to respond (real time is like 60 seconds), then it's most likely software related. Have you restored and setup as a new device? Do not restore from backup as maybe your backup is corrupt. If the problem persists, there might be a bigger problem with your logic board. Doubt it though.
I know it's been a year since you've been here but I came across this looking for links for a customer of mine with the same issue.
Really just posting some info and curious I you got it worked out or just bought a new device.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
After a call to my mobile network operator, it appeared that my warranty was still valid !!
The diagnostic of the problem was just stating : touchscreen freezes randomly.
Solution given by support: replacement with a new iPhone 4.
In conclusion, the origin of the problem has not been found out.
My iPhone was not jail broken and I proceeded to full restoration without use of any backup many times and the problem still occurred.
I don't think it was a memory problem and the freeze was not on certain spots but on the whole screen. Sometimes I could not cut the communication while on call !
As for my new iPhone 4, I did not encounter any problems. I am running the latest iOS version and the phone is still not jail broken.
I hope you will find a solution to your problem.
さんによる
コメントを追加
my i phone 4s is facing a problem of touch some times .
so i have reseted it .but when touch is not working a;; keys are working
and if i restart it again it is working .
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I had similar touch screen freeze-ups and tried the above fixes without success. To fix it I had to back up my iPhone to my computer via iTunes, then turn off Settings/iCloud/FindMyPhone, then Settings/General/Reset/Erase All Content and Settings. Then during iPhone setup, I chose to Restore from iTunes Backup (or something to that effect). Now it works like new again!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hello I have an iPhone 4 and it suddenly had a problem the touchscreen doesn't respond in some apps I tried restoring and it does nothing I can slide it to open but when I use some apps like Safari it doesn't resond. Even when I swipe up to open control center it doesn't respond at all I'm running iOS 7.1.2 pls help
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
if a reflow helped the problem for 3 hours i suggest taking a heat gun and heating the rear glass untill you are certain the internal workings of the phone are red hot. this will melt the salter inside your phone and hopefully fix your problem
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
after i updated my Iphone 5 ios 10.1.1 5 days ago the screen began acting weird (though i don't know if the update is the problem) also i dropped it for maybe 6 weeks ago it will be responsive for about 5 seconds and sometimes it will zoom in and when i zoom out it is so hard the picture will either go up or down and sometimes when i’m sliding left or right it is sliding but rather slow and it is normal to the top right screen part under the front cam to be warm? i just noticed it last night
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
ngtr007 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 31
今までの合計 74,469
