メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2011年に発売された、HP Pavilion DV6-6000シリーズのノートパソコンです。このページでは、デバイスの修理やメンテナンスの手順を掲載しています。
won't turn on
It doesn't turn on even after charging.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @demonslaye17932
Try a full power refresh in case it is a corrupted BIOS and check if that resolves the problem.
Here’s the procedure:
a). Disconnect the charger from the laptop if connected.
b). Remove the main battery from the laptop.
c). Disassemble the laptop and disconnect and remove the RTC coin cell battery from the motherboard.
Here’s the maintenance and service guide for the laptop. Go to p.46 (54 of 123 pdf) and p.50 (58 of 123 pdf) in the manual to view the necessary pre-requisite steps and then the procedure to remove the main battery and the RTC battery, respectively.
When the RTC battery is removed measure its voltage. If it is <2.6V DC or if the battery is >4-5 years old, replace it. The part number is 682091-001. Search online using the part number only, to find suppliers of the part.
d). Press and hold the laptop's Power button for a full 30 seconds and then release it.
e.) Reconnect the RTC battery (or its replacement).
f). Reverse the above steps to re-assemble the laptop.
g.) When the laptop is completely re-assembled, connect the charger and try to turn on the laptop.
If it starts OK there may be a message about the date and time being incorrect. This is normal as the BIOS has been completely reset back to its default settings. Once the date and time have been adjusted the message won’t appear the next time that the laptop is started.
If you had previously changed any user defined settings in BIOS to suit whatever specific hardware configuration that you had for the laptop, then these will have to be set again.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Demon Slayer さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 34
今までの合計 139
