メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Meta Quest 3S 複合現実ヘッドセットは2024年10月15日に発売された、Meta Quest 3の後発の、廉価モデルです。
Headset's tracking completely stopped working
I was playing VRChat on this headset and the tracking on it completely stops working where the cameras are off and the microphone only works if I hold the power button (after 5 seconds of holding it would shut it down) as well as the controllers not responding to anything beside the quest menu button so I had to use the head direction movements and volume buttons to navigate around the menus. I went to the Headset Tracking option and the switch is stuck on as it won't let me toggle it at all.I'vr also used ADB to clear the data of all the oculus system apps and restart it to safe mode but it didn't fix the problem. Is there something wrong with the hardware or does it need to be factory reset?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
I would try to factory reset it but if that doesn't work try to send it back if you have warrenty
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I was just playing vr but end then i didint know that it was the last time to play vr so the tracking device is broken and i do not know how to fix it will you help me
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Kai Bannon さん、ありがとうございました!
統計データ:
過去 24時間: 14
過去 7 日: 50
過去 30 日: 114
今までの合計 667
