Touchpad isn't working.
My Touchpad is not working and the cursor is not showing on the screen. I've tried to check i it is enabled on the settings using (fn + m) but it was already enabled.
What could be the problem?
Well there an be multiple reason for this issue so i will suggest you to checkout the following guide it might help you in fixing the issue: https://www.systweak.com/blogs/how-to-fi...
このアンサーは役に立ちましたか?
When I first encountered this problem, I fixed it by holding the power button for 15sec and my pc would restart itself and the touchpad would be working again.
Now it's no longer working when I try it.
過去 24時間: 0
過去 7 日: 2
過去 30 日: 15
今までの合計 77
