メインコンテンツにスキップ
Mid 2010 Model A1278 / 2.4 もしくは 2.66 GHz Core 2 Duoプロセッサ
締切られた回答
iSight camera light always on
i got this mac book pro 2010 off someone that did not power up no matter what i did.so i toke it apart washing down the motherboard and all components inside.no visible water damage anywhere.only some beach sand inside.it was in Mexico before all the troubles started. now that it powers up only two issues. i camera light is always on. and no sound. tried headphones nothing .did all type off resets on the mb.
shows no audio output under devises. only static at start up.also tried another hard drive with snow leopard to make sure it was not software related same thing.wondering if anyone has any ideas.or should i scrub it down again.thanks.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
Try to unplug the magsafe and take out the battery, hold down the power button for 10 seconds, then replace the battery and power it back on.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Thanks For answering but i already tried that. seems like the issues are coming from the board.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Do an SMC reset, as you were instructed, then a PRAM reset. To achieve a good PRAM reset, boot up the machine keeping option+command+p+r and keep them pressed until you hear three "boing" noises
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
just did a smc reset and a pram rest.im doing them right on the smc the color led changes. and on the pram all setting go back to default. but those two issues still remain.cant hear the chimes only heavy static from speakers.thanks
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,653
