trying everything to see about getting it up.by holding both buttons down then up on the driver's door control, then doing the same with the passenger door with no luck trying do the same thing.
@stuartwhetsell the Legacy and the Outback share the FSM for this series. Anyhow, here is the Glass Windows Mirrors chapter form the FSM. Page 16 is the one of interest since it shows how to inspect the switch and the function.
@andrewjbenner so are you saying that the passenger door window does not go up either by door switch or the master switch on the driver door?
oldturkey03 さんによる
I’ve had this issue. Goes up with the passenger door window switch. But not the master driver switch.
Any thoughts?
Stuart Whetsell さんによる
@stuartwhetsell bad master switch? Have you checked that out yet? Your car the same make and model as for the OP?
oldturkey03 さんによる
@oldturkey03 mine is an 2015 outback. v6.
likely is a master switch. any advice on how to troubleshoot or replace?
oldturkey03 さんによる
