メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Dishwasher won't start; start button blinks 3 times then turns off
My Whirlpool dishwasher (WDF520PADM7, about 6 years old) will not start. I press the start button, it blinks 3 times, then turns off. I have turned off the circuit breaker for 10 minutes or so, hoping this will reset the machine, but no change. I have run the 123-123-123 diagnostic, all the lights on the control panel light up, but the machine does not run through the testing protocol. I have checked the latch and it seems to be a tight fit. The control lock is not on. Do you have any suggestions as to what else I can try for a DIY fix? Thank you.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi @anita47514
The door latch might be tight but this doesn't mean that the door latch switch is working OK electrically.
If you have a DMM (digital multimeter) you could disconnect the power to the dishwasher and then access the door latch and use the meter's Ommeter function to check if the latch switch is working OK electrically or not..
Here's a video that shows how to access the latch assembly that will help.
On p.4 of the tech sheet there's a strip diagram showing the door switch circuit.
If the switch is faulty search online for WPW10653840 to find suppliers that suit you best. (examples only)
Secures the dishwasher door in a closed position during operation.の画像
製品
Whirlpool Dishwasher Door Latch Assembly - WPW10653840
$25.99
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Anita さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 12
今までの合計 159
