メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2012年半ばモデル、A1278 / 2.5 GHz i5または2.9 GHz i7プロセッサ。
Green Light & Nothing More
2012 A1278 MBP 13" 2.5GHz (820-3115) ?
I am getting only a green light on the charger, no fan spin, no boot,zero activity. I have swapped out multiple I/O boards and batteries and convinced the problem is not with them. so, It seems then that there is a problem with the board which has no visible damage or blown chips that I can see under the Michael. From what I understand G3H must be active as I have a green light, so where should I look to check next? I do have a new SMC chip laying around if that maybe needed. Calling on @oldturkey03 & @rashmikand95190 for some tips.
画像
画像
I'm getting 3.46V on here (All 3 of them).
画像
C7040 13.35V / C7030/1 16.67V
画像
I cannot seem to flip the board in FlexBV....
画像
画像
Here is my board (820-3115)
画像
画像
I don't know where they are on this 2012, There are 3 near R36 chips, but not 4. :(
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
14 件のコメント
Michael = Microscope🤦🏻‍♂️
さんによる
@livfe - If Michael was a Scotsman he wouldn't look kindly you looking under him!
さんによる
Sorry had to reply to this one. Hahaha! Oh my
さんによる
@dan0 One way to get a friendly 'Glasgow handshake' I guess :D
さんによる
@livfe Hahaha. I guess so! Won't be a nice smile I guess :P.
さんによる
9件以上のコメントを表示
コメントを追加
3件の回答
最も参考になった回答
@livfe I understand but you are chasing the wrong parts. You are looking for the MOSFETS like Q7055, Q7080, Q7085, Q7030 and Q7035 which are all part of your PBus Supply & Battery Charger circuit
BTW did you notice that your inductor L7030 looks like it got cooked :-) Sure looks like it's toast. That would mean you would not have the ~8.4V on F7040 and thus no power to PPBUS_G3H, which gives you a green light but nothing else ¯\_(ツ)_/¯
Replace the inductor L7030 (IHLP4040DZ) and check again :-)
画像
画像
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
Brilliant detective work, we will update ASAP on this !
L7030 is just a bit rusty looking for sure but 13.35V reading..
F7040 (Small dot under the component 0.000 / Chip above 13.34V
Q7080 gives 15V top 4 connections, lower 4 0.000 :)
さんによる
@oldturkey03 We replaced the L7030 & the tech said everything else checks out OK, but still no fan spin here :(
He also noticed some corrosion in a few places so maybe to much to repair even if possible, but there is still hope.
さんによる
@livfe did you check PPBUS_G3H? F7040 is a fuse. Check for continuity as well. No power on the fuse means you are having issuse with your PBus Supply & Battery Charger circuit
さんによる
@oldturkey03 Not sure if the tech guy went over these things, We will go over it again ASAP.
さんによる
コメントを追加
Green light usually confirms G3H is present. Next, check PPBUS_G3H and SMC_RESET_L to ensure the SMC is actually waking the board. Verify clock and power rails around the SMC before replacing it. Also inspect corrosion near the charger IC and power MOSFETs.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
@rashmikandhil Added image to question.
さんによる
コメントを追加
If there is a green charger light then G3H is present. You can check S5 rails, SMC power/clock signals, and the power-on sequence. If those are missing, the SMC or its surrounding circuitry can be the problem.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Everything is checking out with voltages, it is a difficult one this.
さんによる
コメントを追加
回答を追加する
livfe さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 22
今までの合計 324
