メインコンテンツにスキップ
Xbox One controller was introduced in 2016 with the launch of the Xbox One S and adds Bluetooth support for Windows 10/11. This controller fixes many of the design flaws found on the Model 1537/1697 controllers and is much more reliable. This controller has been replaced with the improved Model 1914 controller.
Why is my Xbox controller double inputing in menus?
In the Xbox menus (system, not game), my controller will always double input using the sticks or d-pad. I move one, it moves two with two separate sounds. It doesn’t do this to other controllers on the same console
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Hi!
It’s recommended to open it up and clean both
Boards completely with isopropyl alchol.
Also clean the rubbers and the pads on the motherboard. If you have issues with the dpad,, there is a sticker on thr board with metal pieces. You can take it off and clean it under there, then put the sticker carefully on it again (make sure to align it correctly) if it’a failing, replace the sticker with a new one.
Please let us know how it goes!
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
But if it were something like residue that can be fixed by cleaning, why would it only happen in System Menus, and not in game menus?
さんによる
Sorry, I assumed that it happened in the menu and in the games it self. Is the Xbox firmware up to date? Are the controllers up to date as well? At this point it sound software related. Did you tried to test other controllers as well?
さんによる
コメントを追加
Sounds like might be a little dirty and it is getting stuck and re-sending the input, without taking the controller apart it is hard to diagnose. Might want to try spraying some contact cleaner directly into where the sticks are and moving them around might break up whatever could be in there.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Thomas Mead さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 17
過去 30 日: 36
今までの合計 36
