メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Nintendo Switch Joy-Con コントローラーの修理ガイドと情報。
Right joycon doesn't connect wirelessly
Hello
my right joycon works only when attached on the switch but does not connect wirelessly when taken off, the switch doesn't even recognize it.
It is not an antenna issue, i've already tried replacing it, its not a switch issue as it works with other joycons, the joycon (that doesn't work) doesn't connect wirelessly to any switch i've tried it.
From reading i suspect it being a problem from the bluetooth chip on the motherboard, any suggestions?
edit: I've tried connecting the right joycon to my phone via bluetooth and it doesn't show up but trying with the left one it does show up
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi!
In this case it does sound like a issue with the bluetooth chip. So replacing that chip will most likely solve it. Soldering is required for this.
I would just replace the motherboard. You can buy them on Ifixit when it’s in stock. Otherwise you can try AliExpress. They are not that expensive, so it’s worth it in my opinion.
Please let us know how it goes!
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
took a long time to get the replacement part, but in the end it works now after replacing the motherboard
さんによる
Alright! Good to hear that it is fixed anyway now :)!
Have a great day!
さんによる
コメントを追加
回答を追加する
Astronyu さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 11
過去 30 日: 24
今までの合計 367
