メインコンテンツにスキップ
2020年3月に発売されたインテルプロセッサ搭載MacBook AirモデルA2179の2020年リフレッシュモデルの修理・分解情報です。
MacBook air backlight doenst turn on after closing lid
When I turn on my MacBook Air A2179, everything is fine, but if I close the lid and open it again the screen doesn’t lit up. I checked with a flashlight and I can see the icons which means that it is the backlight that is not turning on. Anyone knowns what the problem might be? This started to happen when I replaced my trackpad and audioboard
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
The lid has a magnet that intersects with a HALL sensor held within the MacBook Air 13" (A2179, Early 2020) Right Speaker did you damage the logic board connection. Review this guide MacBook Air 13インチ Early Retina Display 2020 右側スピーカーの交換
Replace a right speaker compatible with the model A2179 Early 2020 13" MacBook Air laptop. Fix issues with sound output.の画像
製品
$19.99
このアンサーは役に立ちましたか?
スコア 0
5 件のコメント:
Thank you for the awnser!
The right speaker plugs into the audioboard right?
Maybe the audioboard part I bought was damaged. Because I didn't touch the speaker. Should I replace de speaker or the audioboars?
さんによる
@pedrofranc52755 - That's also possible, why did you replace it?
さんによる
Because of water damage. I replaced the trackpad and the audioboard (and the respective flex cables). The sound wasn't working neither the touchID. With the new audioboard, those problems were solved but now I have this new one. When I close the macbook without shutting off (just sleep mode) when I open it again the backlight doesn't turn on, while the keyboard does.
After i dropped water on it I also got stain on the screen and the camera stopped working, but these issues don't bother me that much.
さんによる
@pedrofranc52755 - I would first replace the speaker as if it got wet the sensor could be damaged.
さんによる
Ok, I will try that
さんによる
コメントを追加
回答を追加する
Pedro Francisco さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 25
過去 30 日: 25
今までの合計 25
