メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Microsoft Corporationが設計したXbox One Sは、2016年8月に発売されました。Xbox One Sは、Xbox Oneを再設計した製品です。
Xbox one s display problem
Hi guys my Xbox one s is not displaying its image properly it started last week I tried everything from rebooting the system to low resolution mode on low resolution mode it works perfectly but on higher resolutions such as 1140p,1080p and 720p it does this I also tried using different tvs and monitors nothing works it works perfectly on low resolution mode but when I change it to a higher resolution the screen just goes to no signal or it works but there's visual glitches all over the screen where it keeps on refreshing the image I looked behind the console but the hdmi port is perfectly functional I tried different hdmi cables wich also resulted into the same results Im curious what could be the issue before I take it to a repair store
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi!
I think this is GPU related as you did tried a lot already.
Replacing the GPU will most likely fix it, but is very difficult to do. You do need to solder and have some serious soldering skills and equipment to get the job done.
Replacing the motherboard will also fix it, but will be more expensive.
Guide: Xbox One S Motherboard Replacement - iFixit Repair Guide
Otherwise it's for the best to bring to a local repair shop to see if they can replace it.
Please let us know how it goes!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Kyle Dasilva さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 8
今までの合計 60
