メインコンテンツにスキップ
2021年10月に発売された、Apple設計のM1 ProとM1 MaxのSoCを搭載した16インチMacBook Proの修理ガイドと分解情報をご紹介します。モデルA2485です。
Display blank after repair; recognized in recovery assistant
Hello,
My MacBook Pro 2021 16 inch had a cracked display, so I bought a shell off of eBay and followed the logic board replacement guide to swap over the logic boards.
I turned it on and the display was blank, however it was recognized in repair assistant as a new part. Once repair assistant did its thing, there was still no video output from the screen. I checked the display connections and they are all I damaged, from what I can see the ribbons are free of damage, and I can verify the display angle sensor works because the Mac enters and exits clamshell mode and boots up when the lid is open.
I’m at a loss for what to do, any advise is appreciated
Update:
running diagnostics returns NDC001; the individual backlight zones light up and are visible in a dark room. The camera works regardless of the NDC001 error, which was due to running diagnostics in clamshell mode
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Sadly the displays are serialized, so swapping the display or transferring the logic board to a different case set is not workable. In addition the power button is married to the logic board so you need to move it with the logic board.
If we speak of a display swap normally you would loose True Tone functionality unless you bought a new display from Apple via their self repair option and then gain access to the paywalled calibration tool. Review this guide MacBook Pro 16インチ 2021 スクリーンの交換 and here's the Apple's Official MacBook Pro 16 2021 Repair Guide
このアンサーは役に立ちましたか?
スコア 0
5 件のコメント:
The touchid lost functionality, which isn’t that big of a deal. I am curious what the repair assistant did if it didn’t reassign the display to the motherboard? From what I know, the repair assistant on iDevices assists in serialization.
And why does a swap work but replacing the whole case doesn’t? The diagnostic returns the display is working, and I can see movement on the
Mini led backlight. I feel like we’re close to a solution. The part wasn’t cheap so I hope I can figure out how to make it work.
さんによる
@ryanshelto25161 - ah! Repair Assistant the first version or two didn't work for me, but that was a while ago. I'm not sure if it will work with two serialization issues at once! I would very carefully transfer the button over to resolve that issue and try again.
さんによる
Yeah unfortunately I already tried to transfer the touch id and broke the original button, so I’m stuck with no Touch ID which is not the end of the world. I am curious as to if there’s any fix for the display? There’s only the miniled backlight zones lighting up, the actual lcd layer appears blank
さんによる
@ryanshelto25161 - Then the display is bad (T-CON) or the jumper cable between the main logic board to the T-CON is bad or the connector pins are damaged (either side) Reference Steps 26 ~ 31 in MacBook Pro 16インチ 2021 スクリーンの交換
さんによる
What’s odd is the display passes the TCON diagnostic. I’m wondering if a dfu update might fix something?
さんによる
コメントを追加
回答を追加する
Ryan Shelton さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 13
今までの合計 77
