メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
第10世代Apple iPadのリペアガイド、分解、トラブルシューティング情報です。Wi-FiモデルとWi-Fi+Cellularモデルがあり、ストレージ容量は64GBまたは256GBです。2022年10月発売。モデル番号はA2696、A2757、A2777、A3162で識別されます。
My iPad won't charge
So my iPad won't charge. When I first bought it (used) it had some charging issues but after some time it worked fine. I sometimes had to turn the Cable because it didn't charge. But now it completely stopped charging. If I connect the charger it does nothing, if i turn it off and connect it, it boots automatically and a message pops up saying "Accessory connected" but it still wont charge. The Port is clean and I've tried many different Cables, including the original one.
About the "Accessory connected" Message, my iPad 7 keeps getting the same message but charges perfectly fine.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
From your description, it sounds like the charging port is starting to fail internally. The “Accessory connected” message usually points to the iPad detecting the cable but not making a solid power connection. Since you’ve already tried multiple cables and cleaned the port, the next step is checking the charging port itself—it may be loose, worn, or have damaged pins.
In many cases, replacing the charging port assembly fixes this completely. If not, it could be a charging IC issue on the logic board, but port replacement is the most common solution.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
flo さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 21
今までの合計 275
