メインコンテンツにスキップ
The JBL PartyBox 300 is a large, powerful Bluetooth speaker that delivers rich sound with a selectable bass boost. It features an integrated light show with various modes that sync to the music. The built-in rechargeable battery provides up to 18 hours of playtime. The JBL PartyBox 300 became available for purchase in October of 2018.
The bottom speaker not working - sounds terrible and staticy
And i don’t know if it’s cause the bottom speaker don’t work but it’s sounds terrible and static
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
@pupusa first do a visual check of your speaker. Check the speaker cone for any rips or tears. Yes, you can gently push the speaker cone inward and if you feel a scraping you may have a damaged speaker. The most reliable test would be to check for continuity and resistance of your speaker. Here is a good guide on how to check speakers and the wiring スピーカーとケーブルのテスト方法
If your speaker checks out okay, you need to check the amplifier circuitry of your PartyBox. For that use the SM that you can find under the Documents Tab on this JBL PartyBox 300 page. Pay particular attention to the capacitors in this circuit.
If you are unsure about those components, post some good pictures of the circuit board with your question. that way we can see what you and hopefully help you out further. iFixitでの質問に画像を追加する方法
iFixitの画像
ガイド
難易度:
とても簡単
2 - 5 minutes
Sony SS-CCP1の画像
ガイド
スピーカーとケーブルのテスト方法
難易度:
中レベル
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
You have to check out the resistance of the speaker, try to manual push the speaker part to check is it stuck in the magnet. If everything's ok with the speaker, check the speaker amplifier IC.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Pupusa さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 47
