メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Nissan Altimaは、日産自動車が製造するミッドサイズセダンです。1957年に始まったNissan Bluebirdシリーズの系譜を継ぐモデルといえます。
My parking lights will not shut off
Hello
My parking lights came on randomly and now will not turn off. Any ideas?
I was going to pull the fuse but an actual way to fix it may be more helpful.
Best
sara
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
5 件のコメント
SaraAltima, any daytime running lights on your vehicle or anything like that?
さんによる
Nope. :(
さんによる
Yes, I am a newbie to this site and can always use another T shirt! :-) Thank you everyone!
さんによる
OK It's Friday night on a long weekend and I need to sleep.
I won't be able to see a mechanic until Tuesday.
How do I disconnect them?
Please and thank you for any assistance
さんによる
I went to the junkyard and got a replacement fuise box the one under the hood next to the windshield fluid box and problem resolved it only cost me 15 bucks
さんによる
コメントを追加
2件の回答
ベストアンサー
The Body Control Module (BCM) controls the operation of various electrical units installed on the vehicle. As I always recommend with computer controlled cars, have the computer memory checked for Diagnostic Trouble Codes first, before spending a lot of time checking or replacing parts.
SYSTEMS CONTROLLED BY BCM DIRECTLY
Power door lock system.
Remote keyless entry system.
Power window system.
Sunroof system.
Room lamp timer.
Key reminder
Warning chime
Turn signal and hazard warning lamps
NOTE: Power supply only. No system control.
SYSTEMS CONTROLLED INDIRECTLY BY BCM
Headlamp, tail lamp, fog lamp, auto light system
Wiper
Front washer
Rear window defogger
このアンサーは役に立ちましたか?
スコア 6
9 件のコメント:
Thank you sir. :)
さんによる
Sara, why did you downvote this answer?
さんによる
Hi there
I am not sure what that means. Did I click something wrong? Tell me how to fix it and I will be happy to help you out.
さんによる
SaraAltima, if you look at HemiBill avatar, just above you see the number 4. To the left of it are two arrows. An Up and a Down arrow. If you click the up arrow, the person, in your case HemiBill, receives points for a good answer. If you hit the down button, points will be deducted from his "account" (no money involved, points are the only reward we are getting:) Down votes are usually reserved for blatantly wrong answers or malicious answers.
さんによる
It's changed now ;-)
さんによる
4件以上のコメントを表示
コメントを追加
I have my middle brake light out and passenger tail light out , I replaced both new bulbs u name it nothing. Even with the driver tail light having operable ruining light the brake feature does not work . I replaced brake and cruise control switch and now have no brake light n no cruise control
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
SaraAltima さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 23
今までの合計 20,900
