メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Can't Boot on Battery Alone
I have tried two iFixit replacement batteries for my refurb laptop.
The original HP battery is functional, but full charge lasts only for about 2.5hrs, so decided to replace.
After intalling the new batteries and fully charging them, the batteries last for 5+ hours, great.
However, if I try to boot the laptop on battery only, the keyboard lights up and power led illuminates for a couple of seconds before powering back off. The screen does not come on.
If I plug in the AC power, it will power on. If I let it boot into windows and remove the AC power, the laptop will remain working on the new batteries. If I boot to BIOS setup and then remove the AC power, the laptop will remain working on the new batteries.
Windows battery reports show the batteries are healthy. Windows HP diags show they're healthy. BIOS/UEFI diags show the batteries are healthy.
I've tried the various power resets, such as holding power buttons with/without battery connected. No luck.
I've reset the BIOS, no luck.
If I put the old battery back in, it boots up successfully without AC power.
Does anybody have any ideas?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
It sounds like the replacement batteries aren’t fully compatible with your HP laptop’s firmware, even though diagnostics show them as healthy. Since the original works fine, I’d suggest updating BIOS/EC firmware and confirming the batteries are genuine HP parts.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hi Rashmi. The replacement batteries are not genuine HP, they are those available from iFixit's store (below) - I did suspect this may be the issue, but equally iFixit comfirmed they are compatable, and they do function once booted.
I did check the BIOS firmware, but it's already at the latest version. (Apr '25)
HP HK04XL Battery
さんによる
コメントを追加
Hi @mattbatey8586
Try uninstalling/reinstalling the Microsoft ACPI-Compliant Control Method Battery driver in Device Manager and check if doing this resolves the problem.
Go to Device Manager → Battery → right click on the Microsoft ACPI-Compliant Control Method Battery entry → Uninstall Device → Uninstall.
Once it has been uninstalled, close all open windows and then restart the laptop in the normal manner.
During the following startup, Windows will automatically reinstall the drivers again.
To get to Device Manager in Win10/Win11, press the Win key + x key (both together) and click on the Device Manager link in the menu box that opens.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hi @jayeff, unfortunately I've already tried this and it hasn't helped
さんによる
コメントを追加
回答を追加する
Matt Batey さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 28
今までの合計 313
