メインコンテンツにスキップ
Repair and disassembly information for Rakuten Kobo’s Clara BW (black and white) eReader, released in April 2024. Identified by model number N365.
Vertical scratch on the screen: is front cover sufficient?
Hi, I have a vertical scratch on my kobo clara bw, as seen in picture. Screen is fully functioning, but I am considering fixing.
To repair, do I need to purchase an entire screen, or would replacing the front cover sufficient?
Thanks
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Thanks. To clarify, the scratch I am referring to is the one on the "white" area (left of the book title), not the black cover on the bottom
さんによる
コメントを追加
2件の回答
ベストアンサー
It doesn't appear you got the answer you were looking for; as far as I can tell the front cover does not come with any glass or acrylic screen; it's nothing more than the shell around the screen.
As such, the only fix for the scratch you're seeing is to replace the entire screen. That basically means gutting the reader, putting in a new screen then rebuilding it with the parts you took off the original. The front glass on the screen is not considered replaceable; the separate layers are all bonded together, so you have to replace the whole thing at once. Here's the iFixit guide to that repair.
Kobo Clara BW (N365) Screen Replacement - iFixit Repair Guide
One note here; rather than answering, I almost skipped by your question because you had already marked the previous answer as accepted. When you do that, many of us volunteers will ignore it, assuming you've gotten whatever answer you were looking for, so you need to hold off accepting an answer until your question has actually been answered to your satisfaction.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
最も参考になった回答
Hey,
Just from looking at this photo, it appears the scratch is just in the front cover, it doesnt look to be screen damage.
Here is a guide to replacing to cover, also on the guide it will have links to everything you need to replace the cover.
Kobo Clara BW フロントカバーの交換
Hope this helps, good luck!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Francesco Gelli さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 38
今までの合計 147
