メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2193回答 すべてを表示
Part left over - Camera not working
Hi
I just replaced the front touch screen. Now I have a part left over that I cannot figure out where it goes. I gone through all the videos and pages and cannot find it. It is black with a hole on the upper right side and a folded clip front on the left with a golden end. The rear side is golden completely.
Alternately the camera does not work. I get the closed shutter. I think they are related
Thks for any help
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
3件の回答
ベストアンサー
The part you have left over is probably the grounding clip of the top antenna:
http://guide-images.ifixit.net/igi/x1kpQ...
Have a look at the display assembly replacement step 19&20
iPhone 4S スクリーンの交換
I however can not really find a relation between a non working camera and this clip missing but it is worth a try,
このアンサーは役に立ちましたか?
スコア 0
5 件のコメント:
No the grounding clip is much longer and has been properly installed. This clip is about 1/4 the size of the grounding clip. A shame I cannot attach a picture. Thks
さんによる
Possibly then the clip that goes underneath the battery terminal? Have a look at step 4/5 of the following guide:
iPhone 4Sのバッテリーの交換
さんによる
Not sure, cannot figure out how it would stay in place.
please check out the part on this link : https://dl.dropbox.com/u/79194393/IMAG00...
さんによる
yes that is indeed the clip that goes under the battery terminal. have a look at the following picture. The clip is held in place with the screw marked with the orange circle:
http://guide-images.ifixit.net/igi/tAZJS...
さんによる
Thanks, that is it. guess I need to change my glasses. I will keep you posted for the camera ??? Thanks very much for your help.
さんによる
コメントを追加
Does anyone know if you can buy this part? Yup my went for a walk an I can't find it anywhere :-(
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Yes, if you have not got it yet. I got one from E bay. It does not have the black coating on the clip, but is identical.
http://www.ebay.co.uk/itm/BRAND-NEW-ORIG...
£4.49 in UK
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Daniel さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 4,501
