How to fix it?
how do you make an ipod work that's screen is falling off.
この質問は役に立ちましたか?
I am not sure if we have enough information about what it is that you need. But if your display is physically falling out/off, check this guide. iPod Touch 4th Generation Front Panel Replacement It will show you how to replace the display assembly and how it is attached. It should help you in determining what is going on with your iPod. Hope this helps, good luck.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 360
