Device will not power on after usb c replacement
Orange jouce was spilled on my MacBook pro M3. After a few days the usb c started to not work. I removed the back cover revealing some corrosion on the main board. (Device was working just fine other than usb c). I removed the main board, cleaned with rubbing alcohol and a new toothbrush. It cleaned up really well. I let dry for 18 hours and re assembeled everything. Now it will not power on unfortunately.
I tried charging it, no light or any sign of life. Holding the power button while plugged in.
I even took the back off and re connected the battery and screen. Still nothing.
Please help! I have no apple store in my country and need to fix this!
Thanks
Good to state exactly where the juice was spilled on the keyboard / logic board and the country you are located in, It is likely there will be a shorted circuit and some board level surgery required & or a defective keyboard power button if the spill was on that location.
livfe さんによる
Juice was spilled on the side of the laptop. By the mag safe and 2 usb c ports. None got on the top of the machine
David W さんによる
