メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
任天堂の最初の3DSモデルは日本で2014年10月に発売され、北米では2015年9月に発売されました。Newニンテンドー3DSは改良された3D機能、Cスティック、本体内蔵のamiiboサポート、そして新しいトリガーボタン一式が特長です。
My 3DS won't turn on
I have had this console for at least 8 months, and it died on me. It was working fine too before it broke. No blue light would appear when I pressed the power button, and when I charge it, the orange light appears, then later dies after a few minutes. The weirdest thing about this error is when every once in a while, the New 3DS would boot on, and the battery would say that it's 3 bars full. Then after like 10 minutes, it shuts off automatically. What can I do to fix this issue? My DSi also died the same way, before the 3DS broke. I even changed the battery, and that still doesn't fix it. I want to deconstruct the 3DS, and see what's wrong, but i'm scared that i'll break the console. Is there a solution to fix this issue, or do I have to buy another one?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
There might be a faulty chip or component on the motherboard. Check if the old battery works on another 3DS. If it does, its a problem with the motherboard. If you're too scared to fix it, try get as much data off the 3DS onto an SD card and send it to someone to try repair it. If that doesn't work then you will need to get a new one. I wish you luck on fixing the 3DS.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Joshua Pangan さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 12
今までの合計 258
