メインコンテンツにスキップ
Xbox One controller was introduced in 2016 with the launch of the Xbox One S and adds Bluetooth support for Windows 10/11. This controller fixes many of the design flaws found on the Model 1537/1697 controllers and is much more reliable. This controller has been replaced with the improved Model 1914 controller.
20回答 すべてを表示
Xbox says controller is disconnected
My Xbox continually says that my controller is disconnecting, even though the light on the controller is still on. I’ve used 3 controller, multiple batteries. I’ve used the USB port in the xbox to charge the controller and it still happens. I’m not exactly sure if this is an Xbox issue or a controller problem. I ordered a new xbox controller and its currently on the way so maybe that will fix it. But any idea will be greatly appreciated. Thank you.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
Can you confirm if you are connecting this to an xbox console or PC please?
Also, can you confirm if what you are using to connect the controller, is it always wireless or do you ever use a USB type cable?
Also, are you using battery packs, as in a pre-made after market battery rather that the traditional AA size standard batteries?
Thanks in advance for your answers :)
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
It is an Xbox one console. It is a wireless controller but i have used the USB port in the console to charge the controller and still no luck. I mainly use battery packs but even with the issue I’ve been having it happens even when I’m using packs or AA batteries. Thank you!
さんによる
コメントを追加
回答を追加する
Nathan Tarr さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 79
今までの合計 79
