メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2020年9月発売。モデル番号はA3028です。
Q30's won't turn on
Initially, the headset was switching itself off seconds after being switched on, during use.
Today, however, it didn't turn on anymore.
If I press the power button or the NC button, the blue light comes on. But it won't turn on.
When I plug in the charging cable, the red light comes on.
With the 3.5mm sound cable, the headset also works.
Does anyone know what might be happening and how I can solve it?
Service is not a possibility, because although the headphones are not yet a year old, I bought them through the official Anker website on Aliexpress and they refuse to provide repairs.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
2 件のコメント
How can I bypass the power button, in order to tell if that is the problem or a dead battery? I have a similar problem, but there's no light when the button is pressed, only when the headphones are connected to the charger
さんによる
@tomasdiazaliste You can bypass the power board by using an AUX / 3.5 mm headphone cable.
さんによる
コメントを追加
1 件の回答
ベストアンサー
@ynae sounds like you may have a power issue going on here. It sounds like you're saying it is all working except that it has that power issue. I would consider starting with a new battery first. Check all the wiring and the power switch while you work on that. Use this guide Anker Soundcore Life Q30のバッテリー交換 to work on it. Let us know what you find out.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Can you tell me where I can find the replacement battery? I'll try to follow the tutorial. Thanks for your help.
さんによる
@ynae all of that will depend on where you are. I would wait until you have the old battery. Then use the numbers on that to do a search. That way you know you will get the right battery.
さんによる
コメントを追加
回答を追加する
Ynaê さん、ありがとうございました!
統計データ:
過去 24時間: 6
過去 7 日: 21
過去 30 日: 101
今までの合計 2,022
