メインコンテンツにスキップ
Appleの2016年ラップトップラインアップの最新モデルは、プロフェッショナルユーザーを対象としています。 15インチ、2880 x 1800 Retinaディスプレイ、クアッドコアIntel Core i7、256 GB / 512 GB / 1 TB / 2TBストレージオプション、16 GB RAM、およびTouch Barを搭載したキーボードです。
20回答 すべてを表示
Are replacement displays made by apple
Are A & B stock replacement displays manufactured and/or refurbished by Apple?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
I do not believe so.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
@qmac52121 @themasterg is right. Apple does not build their displays. Those are mostly LG Display, BOE Technology, and some are even Sharp Corp. Samsung displays are used for the iPhones OLED screens.
The new microLED displays will be Apple's first screens designed and developed strictly in-house, so by Apple itself.
さんによる
コメントを追加
If you are speaking about the display assembly it’s self, Apple has both contracted others to assemble the assembly for them as well as assemble the displays them selves.
The iFixit display stock are refurbished display assemblies recovered from used systems which have been fully tested.
Some displays do come out of the factories in some form and often recovered from the waste bins before being destroyed. To combat this Apple stopped supplying the contractors the firmware for the camera unit, only at the time of fully assembling was the firmware installed. In the newest models the display is serialized which makes salvaged displays and even used ones not usable.
このアンサーは役に立ちましたか?
スコア -1
2 件のコメント:
It clearly states "manufactured and/or refurbished by Apple?" The above answer does not need to be downvoted since it is not wrong nor is it misleading. Time to grow up and to stop the bullying. I am downvoting yours for conduct unbecoming and malignant use of the voting system!
さんによる
@oldturkey03 - reread the Q! Are A & B stock replacement displays clearly he is asking about the iFixit parts! The above answer nor your comment addresses the core aspect of the question! So get off your high horse!
さんによる
コメントを追加
回答を追加する
QMac さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 48
今までの合計 48
