メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Faceplate doesn't tilt correctly
I have a pioneer deh-880prs stereo. Had it for quite some time. Stereo turns on and works. Faceplate will not drop down all the way to unload the CD. How do I fix this without it costing me a ton of money..
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Companies such as CRC make a spray lubricant specifically for electronics. You can try shooting a little bit of electronics lubricant into the faceplace bracket slots (not the CD loading slot). That might help. Be sure to use just a tiny bit of spray and try to get the lubricant's aiming straw poked into the slot so you can reach the inner mechanism. If that doesn't work you'll likely need to disassemble the unit and realign the faceplate mechanism. Easy repair for a professional shop, but it'll still cost a fair bit $. By the way, the Pioneer DEH-880PRS is one of my all-time favorite head units! It's a gem!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
j d さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 24
今までの合計 231
