メインコンテンツにスキップ
5G搭載スマートフォンGoogle Pixel 6aの修理ガイド情報です。2022年7月に発売。
20回答 すべてを表示
Purple spots on phone screen
These purple spots have been appearing on my phone's screen after I dropped it, I was wondering if this can be fixed with a screen replacement or if there is a bigger problem.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
I'm with Brian in saying that a new screen will almost certainly fix the problem with your display. What you're seeing is pressure damage from the components inside the phone behind the screen. It looks to me like the screen fell face down, and the weight of the phone smashed the inside parts against the back side of the screen hard enough to damage it. Compare these pictures to yours and you'll see that you can make out definite features, most notably the battery and the fingerprint sensor.
So yes, order that screen, replace it, and you'll be all set. Here's a direct link to the guide you'll need to do the replacement.
Google Pixel 6a Battery Replacement - iFixit Repair Guide
And you can even buy a genuine Google screen right here as well. If you don't have the tools already, the Fix Kit version is a great deal; for an extra $7 USD the screen comes with everything you need to do the job, including tools and the screen adhesive.
Google Pixel 6a Screen - Genuine
Good luck and let us know how it all turns out!
Replace a front glass digitizer screen for a Google Pixel 6a model smartphone. Features a 6.1 inch 1080 x 2400 pixel OLED Display.の画像
製品
$86.99
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
Got a new screen and installed it. Works good as new. Thank you!
さんによる
@empoleon Fantastic! Thanks for letting us know; anyone else who comes along with that same problem will know just what to do now.
さんによる
コメントを追加
More than likely, yes, a screen replacement will fix this issue.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Empoleon さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 49
今までの合計 49
