メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2022年発売のフルサイズ冷蔵庫、Frigidaire Refrigerator FRSS2623A*に関する修理および補足情報です。本モデルは内蔵型やドアスルー機能のないモデルですが、自動霜取り機能を備えています。このページは、FRSS2623A*のパターンに合致するモデル番号に関する情報を扱います。
Dispenser light doesn't come on automatically
Brand new fridge. Manual suggests the light above the ice/water dispenser should come on when used. It doesn't. The light works when manually turned on, but then stays on indefinitely. Ice, water, and all other functions of the unit seem to work fine. Can't find anything about this issue in official documentation or online, would appreciate any ideas!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
As an electrical engineer, I would assume there's a switch on the activation lever that is supposed to tell the control board to turn on the light when you press the paddle to get ice or water. I know there's one on my old GE fridge and my new KitchenAid as well. Like yours, they both have a separate button on the control panel to turn the light on manually that's independent of the paddle switch.
So my best guess here would be that you've got a defective switch on the dispenser. Of course, it could always be a bad connection or wiring problem, but I'd start with the dispenser switch. Unplug it and short the wires and see if the light comes on. If it does, boom, you've found the problem. Unfortunately, Frigidaire doesn't sell that switch as a replaceable part; instead you have to replace the entire dispenser assembly as one unit. It's number 8 on this diagram.
画像
However, given that it's a brand new appliance, it's going to be under warranty. So your first step before taking anything apart should be to contact their service department and explain the situation. Assuming they agree it should be working, they'll either suggest troubleshooting and/or repair procedures or send someone out to diagnose and repair the problem.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Just a note to the guy with the offensive name who felt compelled to call me an "egotistical $&!*":
It just so happens I am a retired electrical engineer. Why does my saying so bother you so much? Apparently you also missed the fact that I'm a moderator here on iFixit, and thus you're outta here!
さんによる
コメントを追加
Hi @dankemp98999
What is the full model number of the refrigerator?
The frss2623ad0 user manual only shows that the dispenser light is manually operated by selecting the light button on the control panel. No other way it can turn on is mentioned.
The service data sheet¹ for the above model, doesn't show a separate light switch for the dispenser. If it is supposed to turn on automatically when dispensing then it must be contained within the dispenser assembly.
¹ The service data sheet is applicable to all FRSS2623AB_, FRSS2623AD_, FRSS2623AS_ & FRSS2623AW_ models
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Dan Kemp さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 12
過去 30 日: 66
今までの合計 1,243
