メインコンテンツにスキップ
2020年4月に発表、発売された第二世代iPhone SEの修理と分解情報です。
Battery, BMS and all the shenanigans
It's been a while since I did a phone repair but it's time to replace my iPhone SE 2020 (2nd gen) battery. There are so many new strange developments and conflicting info out there that I just need someone to summarise it for me. I want to use a non-OEM battery and conserve valid battery health data.
  • There is a chip (BMS) on the battery which usually keeps track of cycles but in newer iPhones also holds some kind of serialization data right?
  • This board needs to be soldered on to the new battery. However some are saying you need to utilise spot welding here and soldering wouldn't work, is this correct?
  • What's up with the programmers? Do they read the BMS and copy it on a new battery BMS? If so, would that mean that I could use a programmer to avoid soldering / welding the BMS
  • And apparently after programming the BMS on the new phone you still need to do factory reset to get back to 100% battery status report. Why is this? Is it because iOS assumes it's the same battery and thus can't have 100% health?
  • Also, what is this tag on flex stuff? Is it a replacement solution for transfering the BMS?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
Did you read this guide?
iPhone SE 2020 バッテリーの交換
I don't have an se 2020. But the guide doesn't mention the BMS.
さんによる
Yes of course. It doesn’t answer any of my questions :)
さんによる
コメントを追加
1 件の回答
ベストアンサー
Hi Sam,
I've been doing my best to keep up with Apple's parts pairing, which is only getting worse as the newer generations come out. I'll pass along everything I know about what you need to do to successfully replace your battery.
First of all, the admonishment about spot welding is primarily due to the fact that heat is deadly to Li-Ion batteries. A spot welder will not transfer heat from the terminal tabs to the battery itself, whereas it's easy to transfer heat when soldering. However, that's not to say it can't be done; you'll just want to be as sparing as possible with the heat from the soldering iron to avoid transferring it up the terminal strips to the battery.
Serialized battery
All iPhone batteries since the beginning have incorporated a Battery Management System, or BMS, into the battery. This small circuit communicates with the phone's processor and contains sensors to measure the battery current, voltage and temperature. It also stores the battery health (0 to 100 percent) and the battery's cycle count; the number of times it's been charged and discharged.
With the release of the iPhone XR and later models, the BMS is now paired to the logic board and will result in an Important Battery Message warning and the loss of battery health information if the battery is replaced. For the first 15 days or so a pop-up message will appear on the phone with the following message.
Under the Battery Health section of Settings, a similar message will appear permanently.
The Maximum Capacity and Peak Performance Capability fields will be blank as well.
Note that the battery will still charge and operate normally. This will occur whether you use a genuine Apple battery or an aftermarket replacement.
The aftermarket industry has created a workaround to avoid that message and the loss of battery information. The procedure is to cut the BMS from the original battery and spot weld it onto a new cell. Manufacturers have started offering batteries with just the cell and not the BMS specifically for this purpose.
Once the BMS has been transferred to the new cell, the battery can be used but the old battery information will still be present. In order to reset it, a device programmer such as the JC V1SE or the QianLi iCopy can be hooked up to the battery and used to reset the battery health back to 100 and the cycle count to zero.
iPhone XS -12 Pro Max Important Battery Message Pop-ups Removing - 100% Fixed - iFixit Repair Guide
(4) Remove Non-Genuine Battery Warning / Important Battery Message On iPhone XS And Above - ALL About iPhone Repair - Quora
This next part is something I have been hearing about but I need more information regarding. Apparently the battery must be "activated" after swapping the BMS by applying approximately 4 volts to it.
It's my understanding that this should be all you need to do in order to have a fully functional aftermarket battery working in your phone. If you'd like to know more about the Tag-On flex device, read on, but it doesn't apply to your phone.
Battery health encrypted (Tag-on flex required)
With the release of the iPhone 11, Apple changed the way the battery health information is stored, and made it so that it is no longer possible to reprogram battery health information; even with the BMS swapped over, the health data is now stored on the processor rather than the battery and can no longer be rewritten with a device programmer.
Aftermarket manufacturers have developed a device called a tag-on flex circuit that goes between the battery and the logic board and allows the health percentage and cycle counts to be reprogrammed. The tag-on board is permanently installed into the phone.
One UK site seems to be indicating that the tag-on flex alone can allow you to eliminate the service message without needing to swap the BMS.
iPhone 11 Tag-On Flex For QianLi Copy Power Battery Data Corrector — Repair Outlet
iPhone 11 battery replacement tag on flex issues : r/mobilerepair
XCAP - BMS Tag On Flex - No Programming - For iPhone 11 - ReplaceBase
In your particular case the device programmer would not be used to copy anything; rather it is only used to reset the battery health to 100 and the cycle count to zero. Since your new battery cell has the old BMS, if it's not programmed it will show the exact same information it did before you put the new cell on it. Resetting it starts it over the same as a new battery.
By the way, most of iFixit's guides don't go into detail about implications or consequences of replacing paired parts; I'm guessing they don't want to get into the weeds like this answer is when their purpose is to show you how to replace that particular hardware.
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
Amazing post my friend! This answered all my questions and then some. Only thing I'm still wondering is: if I'd get a battery with increased capacity (more capacity than original) if the BMS swap + reprogramming would still work.
さんによる
@capacitor That's a sticky one. The battery capacity information has to be stored in the BMS, so swapping over the BMS means the capacity being reported will be the same. Now it does appear that the phone is capable of monitoring how much charge the battery does take in order to calculate the maximum capacity so it may recognize a larger capacity battery and show the proper percentage and amount of charge. However, since the maximum capacity is hard coded and the battery may take more than that, it's hard to say what would happen. My personal guess is you'd see a charge level appear somewhere that exceeds 100%, but otherwise I don't think it would cause issues. I'm sure there's some kind of provision for that since it can't be a unique situation that a given random battery may end up being able to take even a little more charge than is specified.
さんによる
@capacitor Keep in mind that battery vendors have been scamming people for years with so-called "high capacity" batteries when the fact is that Li-Ion batteries have not had any significant advances in power density in a very long time. As a result you can usually rely on the fact that a given battery's capacity is strictly a function of size; the way to get one to hold more charge is to make it bigger. Since phones are strictly constrained on the amount of room inside for a battery, there's generally very little that can be done to increase the capacity.
The myth of the "high capacity" batteries
さんによる
Very true Jerry. I'm fully aware of those. I get my batteries from a solid EU based B2B reseller with official partnerships with various brands so they get the benefit of the doubt. Would still love to do a capacity test.
さんによる
コメントを追加
回答を追加する
Sam さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 70
過去 30 日: 293
今までの合計 2,522
