メインコンテンツにスキップ
2018年7月に発売された15インチMacBook Proです。モデル番号はA1989です。15.4インチ LED-Backlightディスプレイ、True Toneテクノロジ、TouchIDと最大6 Core i9プロセッサを搭載しています。
After changing the battery my MacBook Pro won't boot up
I changed the battery on my 2018 macbook pro with a kit from Ifixit and now it's dead. It won't even try to start. I have dual boot with a one partition having windows and the other partition mac os. Before starting the repair, I set the mac os partition to be the automatic side to boot up and then followed the instructions to turn off the auto boot. The old battery was swollen and giving some problem but it had been working. The repair went perfectly, so I can't figure out what's wrong.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Check the MacBook Pro 15" Retina (Mid 2018-2019) Battery Daughter Board Cable is not damaged as well as the ZIF connectors are latched per Step 1 in this guide ケーブルコネクタの識別と接続の外し方 here after re-inserting the ribbon cable we need to carefully fold the latch down to compress the cable.
Replace the small flex cable that connects the battery daughter board to the logic board.の画像
製品
$14.99
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I checked that connection and the other ones too. Everything is fine. Can the cable be damaged even if it still looks good? I checked the battery voltage after charging it for an hour or two and there was no increase. So I don't think the battery is getting any power. Is it possible that something happened to my logic control board when I took it out?
さんによる
@jms83415 - Over bending and sharp creases can damage the cable. Could you have damaged to ZIF socket? Post some pick on the connections here so we can see get in tight with lot of light.
As the battery was swollen and if the battery had already been replaced before then it’s possible the charging logic within the logic board is having issues.
Let’s get a better view of things install this gem of an App CoconutBattery post a snapshot of the apps main window here as well.
さんによる
コメントを追加
回答を追加する
jms さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 18
今までの合計 53
