メインコンテンツにスキップ
クラシック Xbox ワイヤレス コントローラーの 3 番目のリビジョンは、Xbox Series X および Series S にバンドルされて 2020 年 11 月にリリースされました。このコントローラーは、以前の Xbox One コンソールおよび PC と下位互換性があります。
View button sometimes not registering when pressed not in dead center.
Hey guys!
My new Xbox controller has an issue whereby the View/Select button only responds when pressed dead center, when pressed on a angle (like for example by the left side), sometimes it doesn't register, the pause button exhibits the same issue when pressed on the left side/angle. I cleaned it with isopropyl alcohol and still the same thing, can this be fixed with use? Is it a defect?
Any way to fix it without opening the controller? I'd rather make that the nuclear option since the shell starts creaking lol
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
The buttons are probably worn out then. They are small and will fail after a number of uses. You could try and solder new buttons on the board if you think you can do this
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
It's brand new tho, 3 to 4 days old, took it out of a sealed box myself. When I push the button, there's a play before the button "clicks" so maybe it needs to be used for a few days, get the button to break in like they say? (Also I think the issue is in the plastic "button" that sits between the physical and on-board button)
I live in a country where there's no warranty, so I can't send it back to the seller and would cost me a leg to ship it to France for Microsoft's warranty service. And opening the controller is, as I said, risky since they always start creaking after I open them.
さんによる
コメントを追加
回答を追加する
Rachid Rahmoune さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 7
今までの合計 81
