メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Appleのメインストリームとなる2020年iPhoneモデルは10月23日に発売されました。6.1インチOLEDディスプレイ、デュアル12MPカメラシステムと5色のカラーバリエーションがあります。iPhone 11の後継モデル。
battery replacement gone wrong
so i just finished replacing my battery after watching youtube videos (i'm a beginner) and now my screen dosent show anything, i unplugged the connector for the new battery and connected the old battery and that one didn't turn anything on either.. keep in mind my phone was working fine other than a low battery health, can anyone tell me what this problem could be from?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Its sounds like you have damaged your screen during removal... easily done!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Most commonly an issue such as yours is related to either the connector on the motherboard or at the end of the screen's flex cable. If you're new to those delicate little plugs, it's pretty easy to damage them by pressing too hard or not getting the plug lined up exactly right before pressing the connector in place.
I'd suggest unplugging the display cable then check it carefully on both sides with a magnifying glass and a bright light. You'll be looking for bent or broken pins; bent ones can sometimes be straightened with fine tip tweezers, but missing pins will either mean replacing the connector on the motherboard or getting a new screen.
Assuming the pins all look straight and present, you'll want to clean both sides of the connector with 90% or higher concentration isopropyl (rubbing) alcohol, give it a minute to dry, then carefully reconnect the display. Pay attention to the comment at this point in the battery replacement guide:
Give that a try and let us know what happens.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Tammy Allen さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 10
今までの合計 110
