My iPhone 12 pro keeps restarting every 2 minutes
I'm pretty sure it's the charging port. Can someone see if it restarts after like 3 minutes after disconnected. Here's the panic log
That's a big 10-4, good buddy. Charging port it is. The panic log is showing that it can't communicate with sensor PRS0, which we believe stands for Pressure Sensor, connected to the barometric port on the charging port assembly.
So yes, changing out the charging port should indeed fix the problem. Unfortunately, iFixit doesn't have a guide for that specific repair, but there's the Spanish site Nadie Me Llama Gallina that has exactly what you need. As might be expected, the site is in Spanish, but if you use the Chrome browser's language translation it is quite usable.
Manuales / Apple iPhone 12 Pro / Load flex - Nadie Me Llama Gallina
Good luck and let us know how it goes. While you work, take lots of pictures and once you're done you can use them to create your own guide to that repair and help out those who come after you.
このアンサーは役に立ちましたか?
Will a regular iphone 12 port work on the pro
Also I'm not making a tutorial the insides of my phone is massacred
@cloudincor55933 As it turns out, the iPhone 12 and iPhone 12 Pro both use the same lightning port assembly, so yes, you can use one from a 12 on your pro.
iPhone 12/12 Pro Lightning Connector Assembly
You're technically supposed to get one that matches the color of your phone, but it's strictly a cosmetic issue so use whatever color strikes your fancy.
過去 24時間: 1
過去 7 日: 9
過去 30 日: 32
今までの合計 361
