メインコンテンツにスキップ
Xbox One controller was introduced in 2016 with the launch of the Xbox One S and adds Bluetooth support for Windows 10/11. This controller fixes many of the design flaws found on the Model 1537/1697 controllers and is much more reliable. This controller has been replaced with the improved Model 1914 controller.
Why is my controller making static sounds?
My Xbox controller is making this weird static sound when I hold it to my ear. It's hard to hear unless listening for it, but now I've heard it I can't un-hear it. How do I fix?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
7 件のコメント
Hey there Thomas, are you able to hear the static when the batteries are removed from the controller? I'm wondering if maybe this isn't an electronic issue, but rather an issue with debris inside the controller.
さんによる
I can hear it with batteries or when it is plugged in to my PC via a micro-usb cable
さんによる
Does the controller work fine?? Could be a small component on the motherboard.. controller is up to date??
さんによる
@koppie007 its fully up to date according to my Xbox, it works completely fine. It goes away if I were to press in my stick
さんによる
Ah, which stick? Left or right? You could replace it and see if that solves it..
さんによる
2件以上のコメントを表示
コメントを追加
1 件の回答
ベストアンサー
I FIXED IT. I just unplugged everything, and plugged it all in
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Ah good to hear!! Have fun gaming :)!
さんによる
コメントを追加
回答を追加する
Thomas Mead さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 17
今までの合計 44
