メインコンテンツにスキップ
The Dell Inspiron 7306 is a 2-in-1 manufactured by Dell. Specs: Inspiron 7306 2-in-1, 11th Gen Intel(R) Core(TM) i7-1165G7 @ 2.80GHz Processor, 16 GB DDR4 RAM 512GB NVME SSD (not replaceable)
2回答 すべてを表示
Motherboard Crashed after tech “attempted” to diagnose.
Long story short, my laptop was losing its charge. After getting it diagnosed, I was told it was at the end of its life. If it doesn’t turn on, is it still possible to retrieve its stored data? TIA
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hi @jalenahood, there are some ways you can try.
Ideally if the computer is able to boot up to windows,
I would suggest to check and backup bitlocker keys.
https://www.dell.com/support/manuals/en-...
Based on the battery replacement guide, on step 5,
i can see the there is nvme ssd.
Dell Inspiron 7306 P125 Battery Replacement
you can consider getting this usb enclosure
https://www.amazon.sg/ORICO-M-2-Enclosur...
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I tried a battery replacement. It no longer turns on. After the replacement it slowly lost its charge and plugging it in does nothing.
さんによる
@jalena
try disconnecting the battery from the laptop and power on the laptop with just the power adapter.
does it works?
さんによる
コメントを追加
回答を追加する
Jalena さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 10
今までの合計 17
