メインコンテンツにスキップ
Dell Inspiron 7306 P125 Battery Replacement
必要な工具と部品
  1. Dell Inspiron 7306 P125 Battery Replacement, Battery: 手順 1、 2の画像 1 Dell Inspiron 7306 P125 Battery Replacement, Battery: 手順 1、 2の画像 2
    • Turn off the laptop with the power button and close it.
    • Disconnect any power sources from the laptop.
  2. Dell Inspiron 7306 P125 Battery Replacement: 手順 2、 2の画像 1 Dell Inspiron 7306 P125 Battery Replacement: 手順 2、 2の画像 2
    • Use the Phillips #00 screwdriver to remove the seven M2x4 screws from the back panel of the laptop.
  3. Dell Inspiron 7306 P125 Battery Replacement: 手順 3、 3の画像 1 Dell Inspiron 7306 P125 Battery Replacement: 手順 3、 3の画像 2 Dell Inspiron 7306 P125 Battery Replacement: 手順 3、 3の画像 3
    • Grab a corner of the back cover or use a spudger to lift the cover.
    • Pull the cover up around the edges until it is completely removed.
  4. Dell Inspiron 7306 P125 Battery Replacement: 手順 4、 2の画像 1 Dell Inspiron 7306 P125 Battery Replacement: 手順 4、 2の画像 2
    • Remove the three tapes on the left, middle, and right of the battery.
  5. Dell Inspiron 7306 P125 Battery Replacement: 手順 5、 3の画像 1 Dell Inspiron 7306 P125 Battery Replacement: 手順 5、 3の画像 2 Dell Inspiron 7306 P125 Battery Replacement: 手順 5、 3の画像 3
    • Remove the three M2x3.5 screws that have a screw icon above them with the Phillips #00 screwdriver
    • Do not interact with the object located to the left of the middle screw.
  6. Dell Inspiron 7306 P125 Battery Replacement: 手順 6、 2の画像 1 Dell Inspiron 7306 P125 Battery Replacement: 手順 6、 2の画像 2
    • Pull the battery cable towards the direction of the opening.
    • Do not pull the cable upwards.
  7. Dell Inspiron 7306 P125 Battery Replacement: 手順 7、 3の画像 1 Dell Inspiron 7306 P125 Battery Replacement: 手順 7、 3の画像 2 Dell Inspiron 7306 P125 Battery Replacement: 手順 7、 3の画像 3
    • Insert the new battery. Align the holes of the screwdriver with the center object.
    • Apply the tape from the wires to the battery once more.
    • Ensure that the cover snaps into place when closing the back cover.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Arturo Gonzalez
メンバー登録日: 03/29/23
172 ポイント
1ガイドが承認済み
チーム
CSU Los Angeles, Team 2-73, Briggs Spring 2023 CSU Los Angeles, Team 2-73, Briggs Spring 2023人のメンバー
CSULA-BRIGGS-S23S2G73
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 21
過去 30 日: 87
今までの合計 1,403
