LCD replacement or whole unit
Can the screen be replaced as in older models or do you have to buy the whole assembly?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
You can replace just the display but it is a difficult, sensitive task.
If this Answer is helpful please remember to return and mark it Accepted.
このアンサーは役に立ちましたか?
I agree with machead3, I myself tried to open the top assembly, I used a heat gun, no problem in opening it, the real pain was to remove the lcd, I ended up in damaging the led strip and now I need to change the full assembly...
過去 24時間: 0
過去 7 日: 3
過去 30 日: 6
今までの合計 1,270
