メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
JBL Tune 760NCは、JBL 760NCとも呼ばれる、アクティブノイズキャンセリング技術を搭載しクリアなサウンドを実現するワイヤレスヘッドホンです。軽量で折りたたみ可能な設計のため、長時間のリスニングにも適しています。
Why isn't it charging?
The light turns on and it starts charging but then stops.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
最も参考になった回答
@isabellakatz sounds like your battery control board is telling your charger to stop charging. Start off by replacing the battery. Since iFixit does not yet have a specific guide for this, use something like this video
While you work on your headphones, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I had the challange, that the JBL 760NC did not charge anymore and the headphones had no power at all. Hard reset and stuff did not work. I followed the instructions of the video to remove the earpads from the headphones. Then i took hard plastic to open the left head phone with the battery enclosed. As in the video indicated, you have to start from the the upper side where there is the cover shape visible. You have to pull quite with some force and use rather hard plastic (iFixit Tools) instead of the hard knife in the video (i did it wiht my finger nails and the weak one got a small dent). With this method, the plastic cover wont get borken or taking another color.
When opened, I saw that the battery was not connected. So I plugged in the battery and the headphones were running again. I was able to charge and the headphones had power from the battery enclosed.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Hello,
I had the same problem and just lightly smacked the place where the battery is (left earcup) and now it works (miraculously)
I don't know if it will help you, but I hope it will.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Isabella Katz さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 21
過去 30 日: 74
今までの合計 1,528
