メインコンテンツにスキップ
The Backbone One is a mobile game controller for the iPhone. It was released in October, 2020.
A bug(living creature kind) got in my backbone
My left trigger and joy stick started acting funny, like they were constantly being pressed. Decided to pop it open to see if there was any obvious problem. Nothing seems broken, but there was an actual insect inside.
If you open up the sides and put the controller face up, there is a little square ish piece of tape(?) inside the back half near the top. I'm assuming it's a little bit of padding to reduce noise from releasing the trigger. The insect was underneath that. It's big enough you can see it's bent and squished from the trigger hitting it. I'm guessing this kept the trigger slightly pressed. I got the insect out, but my left trigger won't work now. Any suggestions?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント:
Ironic, isn't it?
さんによる
XD yep. Seems the insect wasnt the problem though
さんによる
コメントを追加
1 件の回答
Honestly, I'd recommend replacing the trigger. There's a guide here, but I have no idea where to get replacement parts from. Maybe check ebay? Otherwise, you might be able to send it in to Backbone for repair.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
J Dex さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 102
