メインコンテンツにスキップ
Backbone One Left Trigger Replacement
必要な工具と部品
  1. Backbone One Left Trigger Replacement, Unfasten the screws: 手順 1、 1の画像 1
    • Use a Phillips screwdriver to remove the four 5.9 mm-long screws.
  2. Backbone One Left Trigger Replacement, Rotate the upper cover: 手順 2、 3の画像 1 Backbone One Left Trigger Replacement, Rotate the upper cover: 手順 2、 3の画像 2 Backbone One Left Trigger Replacement, Rotate the upper cover: 手順 2、 3の画像 3
    • Lift up the upper part of the controller.
    • Swing over the upper cover and place it on the controller case.
    • Take care that the interconnecting cable has no tension.
  3. Backbone One Left Trigger Replacement, Remove the protective tape: 手順 3、 3の画像 1 Backbone One Left Trigger Replacement, Remove the protective tape: 手順 3、 3の画像 2 Backbone One Left Trigger Replacement, Remove the protective tape: 手順 3、 3の画像 3
    この手順で使用する道具:
    • Use a pair of tweezers to remove the yellow protective tape which is placed over the interconnect cable connector.
  4. Backbone One Left Trigger Replacement, Open the ZIF connector: 手順 4、 2の画像 1 Backbone One Left Trigger Replacement, Open the ZIF connector: 手順 4、 2の画像 2
    • Use the tip of an opening pick to open the gray flap of the ZIF connector by pushing it upwards.
  5. Backbone One Left Trigger Replacement, Disconnect the interconnect cable: 手順 5、 2の画像 1 Backbone One Left Trigger Replacement, Disconnect the interconnect cable: 手順 5、 2の画像 2
    • Use your fingers to disconnect the interconnect cable from its connector.
  6. Backbone One Left Trigger Replacement: 手順 6、 2の画像 1 Backbone One Left Trigger Replacement: 手順 6、 2の画像 2
    • Remove the upper half of the left controller assembly.
  7. Backbone One Left Trigger Replacement, Remove the screw: 手順 7、 2の画像 1 Backbone One Left Trigger Replacement, Remove the screw: 手順 7、 2の画像 2
    • Use a Phillips screwdriver to remove the 5.9 mm-long screw which is securing the trigger.
    • The screw is difficult to reach. Insert the screwdriver at an angle of 45 degrees.
  8. Backbone One Left Trigger Replacement, Remove the trigger: 手順 8、 2の画像 1 Backbone One Left Trigger Replacement, Remove the trigger: 手順 8、 2の画像 2
    • Remove the left trigger.
終わりに
Repair didn’t go as planned? Ask our Answers community for help.
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Adriana Zwink
メンバー登録日: 12/18/19
62,471 ポイント
167のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
23,746のガイドは作成済み
1件のガイドコメント
Where can I buy the trigger
Zach - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 16
過去 30 日: 65
今までの合計 3,466
