メインコンテンツにスキップ
Appleの消費者向け人気ラインのMacBook Airの修理ガイド
4820回答 すべてを表示
curser is stuck in upper right corner
My Mac book Air pointer is stuck in the upper right corner and will not move.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
First things first: provide us with the last four letters of your serial code.
I also take your keyboard is working fine... or it isn't?
While we wait for more informations, try the following things:
  1. Reset your SMC, as told in the Apple Guide, and try again. Is your trackpad working? If not;
  2. check what happens if you connect an external mouse, an economic, "windows" spare is fine, I use a Microsoft older than dirt with my Macbook and it never complained. If your keyboard has issues too, try with an USB keyboard as well Is your laptop working fine with an external mouse? If it does
  3. Try creating a new user account, or better, reinstall OS X on an external disk, if you can, or backup your data and try a fresh install
If it keeps being stuck, you may have a broken trackpad.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
  1. Turn off your mac.
  2. Press the shift key on the left and the power button simultaneously to switch on your mac in “safe mode".
  3. If it was a software error your cursor should work fine in safe mode.
  4. If the issue doesn't persist when your Mac is started in safe mode, try restarting without pressing any keys.
    • If the issue comes back, you might have incompatible login items.
    • If the issue doesn't come back, it was probably caused by a cache or directory issue with your startup disk, which safe mode fixed.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Mark Atkins さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 6
過去 30 日: 9
今までの合計 8,731
