メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2011年に発売されたSony EricssonシリーズのAndroidスマートフォン。
How can I fix phone's touch screen?
The screen has a small crack on it and isn't working around that small part. It's exactly around where I would have to open my phone by swiping.
Is there a way to change/fix the touch screen? If so; how?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
If you can find a screen replacement for it yes. It might be hard to find one as it’s an old phone.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
@khaki2440 you will need to replace the complete display. Use this document Working Instructions Mechanical to work on it. Not terribly complicated and pretty straight forward. The LCD is still available at a few online places. Otherwise, you may have to look for a donor phone that has other issues but a working display. Then harvest the screen from that. Look for Sony part number 1242-7342
Update (08/26/24)
@khaki2440 as was correctly pointed out, the touchscreen is separate from the LCD. Sony part number is 1249-3415 black, 1249-4115 Red and 1249-4116 for the silver. Frame and Touch Panel are identical for Sony Ericsson Xperia Pro (MK16, MK16a and MK16i). You'd be looking at something like this (Check with these people and see if it is compatible with your model.) Quite costly since I am sure there are not a whole lot left of these. A donor phone might just be the way to go.
As for the repair, the previously attached document is still valid for this.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
The digitiser (touch screen) and LCD are separate I’m pretty sure on this phone. Digitiser for this phone is no longer made even is it?. It would have to be a parts phone. Unless anyone has a link?
さんによる
コメントを追加
回答を追加する
Khaki さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 16
今までの合計 227
