メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2021年2月に発売されたSamsungのAndroidスマートフォン、Galaxy A32 5Gの修理および分解情報です。
It won't turn on
Hi,
It all started unexpectedly when the phone started restarting itself every few minutes. After rebooting, I checked the health app and it says everything is fine.
Then it started losing cell connection, it was showing that it was missing signal. I tried to change the mode to manually select a cell carrier, but it wouldn't let me change anything. After I manually restarted it, the connection came up, and everything worked flawlessly for the next few minutes, then the phone lost signal again. In the meantime, I even managed to make a few calls. After another restart, the phone didn't turn on at all.
Because I didn't want to initially open it myself and touch inside, I took it to a Samsung service center where I was told that the connector on the main board was probably broken because when the guy pressed it from behind in a certain spot, the screen was on it trying to boot. I left it for diagnostics as I was advised. But after the diagnosis they offered to replace the main board for the price I bought the whole phone for, and I declined.
After the diagnosis, the phone tries to turn on, but fails to load the android and goes off again, on the second or third try it is dead again.
I opened the phone and removed the main board. Apparently the connector is sturdy and the board is without any visible problems.
I ordered a spare main board from eBay, removed from a working phone and tested, according to the seller. I haven't received it yet, but I'd like to know what happened. This progressive deterioration, without shock or any external impact seems strange to me.
I would like to repair my mainboard if possible as there is inofrmation there which I would like to save.
In the meantime I also bought a spare connector, but apparently the connector has no problems so I didn't attempt to replace it.
Can anyone give any advice? I notice that almost no one here uses and has almost no information on Samsung A series phones.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @dvp
Here's some information that may help.
Sm A326b Disassembly & Reassembly Sm A326b Troubleshooting Sm A326b Electrical Part List
Go to p.7/50 in the Troubleshooting manual to view the troubleshooting flowchart for the phone does not power on problem.
Use the search function in your browser to find the location of the components in the board layout diagrams nominated in the flowchart. You may have to zoom in a lot to find them.
If you find a component is faulty, locate the component designation in the electrical parts list to find the Samsung part number for the part. Search online for the part number to find suppliers that suit you best.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
Hi jayeff,
Thanks a lot for your answer. Could you help a bit more please?
On the troubleshooting flowchart step I find the following:
"Check the signal of AP_GOOD= 1.8V"
Please excuse my ignorance, where is AP_GOOD signal located? I tried by myself, but didn't find it. I suppose it is around U5000 or UCP4000.
さんによる
@dvp
As per the flowchart check the voltage levels on the capacitors mentioned i.e. C5142 = 1.8V - C5104 = 2.8V - C5083 = 2.2V. (all +/-10%)
Locate these components on the board as I suggested above and check
さんによる
check tp4000 testpoint =1.8v
さんによる
コメントを追加
回答を追加する
dvp さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 31
今までの合計 683
