Correct screen for model?
My screen is broken but I don't know how to find the model number. Does the screen differ based on the model?
Hi @jghunter
All the models have a 6.4" amoled display so chances are the same one is used for every model variant.
Here's the ifixit Google Pixel 6 スクリーン交換 guide, that may help.
ifixit also sells the OEM display assembly
このアンサーは役に立ちましたか?
Hi,
If you can still use the screen, then go to settings/about and the details will be there.
If you have no access through the screen then you can go to this link
https://www.phonemore.com/models/google/...
You should be able to identify your model from there.
Hope this helps
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 111
