メインコンテンツにスキップ
Released in May of 2020, Model Numbers: SM-A217F/DS (Global), SM-A217F/DSN (Russia), Processor: Exynos 850, 3GB/4GB RAM, 6,5" inches display, 5000 mAh battery with 15W fast charging and USB type C.
20回答 すべてを表示
My dropped my phone in water about 2 weeks ago
It's been water damaged for a while, I didn't have isopropyl alcohol as its hard to get pure 99% where I live, I used baking soda and distilled instead to clean the motherboard scicne it was recommended but the phone still doesn't work even when the motherboard looks clean, what should I do?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Does the phone show any signs of life at all, like buzzing or vibrating when you plug in a charger or press the power button, or else being recognized when you plug it into a computer?
You could be looking at a dead display, a dead battery or both. Those are the two parts most commonly damaged by liquid exposure. If you've got signs of life, I'd start with replacing the screen first, but if not the battery would be the place to begin.
The battery isn't too bad to replace, but the screen can be a bit of a pain if you need a new one. Here are guides for both repairs in case you need them.
Manuales / Samsung Galaxy A21s / Battery
Manuales / Samsung Galaxy A21s / Fullscreen
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
@queenofthestoe besides replacing the battery, you have to take a close look at your charging board. Remember, that is your DC in board, essentially your power board. What is importance is really the cleaning. I understand the predicament with the Alcohol, but you did not tell us if you removed all the EMI shields, which is a must. If you do not replace those, you can't properly clean the board. Also, make sure that you rinsed the board well with distilled water after.
In all honesty, with the Samsung phones that I have worked on, I have never had good luck with repairing this board. I have now gone to replacing it instead. It is not very expensive and use something like this guide to replace it. It is in Spanish, so use a web browser that will translate it for you (if needed).
Then, with the battery replaced re-evaluate and see what you get. For now I'd ho;d off with replacing the screen until you at least have some sort of sign-of-life from your phone. If it is the display, then your phone will at least vibrate when you turn it on. In that case, replace the LCD.
If nothing else works, you'll have to follow the Samsung flow chart for the No Power situation and see if you can narrow down a component error on the main board
TP stands for test point and all components etc. are marked. Check those for the proper voltages. Anything past this check will become a boardlevel repair. Schematics are available but you ill need to have the proper tools and experience to trace the circuits etc.
Water damage is pretty much the hardest to repair, since practically any component can be a faulty one. iFixit will at least give you a chance :-)
Repair is War on Entropy!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Queen Of The Stoe さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 3
過去 30 日: 8
今までの合計 36
