メインコンテンツにスキップ
2023年10月に発売されたGoogleのスマートフォン「Pixel 8 Pro」の修理・分解情報。型番はG1MNW(NA/AU)、GC3VE(EU、インド)、GE9DP(JP)です。
15回答 すべてを表示
My phone died after dip water diving in the sea what should I do now?
i made a diving into the sea with my pixel 8 pro when i got out of the water the phone was ok and everything was fine after about 5 minutes there was a warning on the screen i didnt get to read that and the phone turned off then i tried to turn it on several times and every time it was turned on and after about 30 secounds shot down now the phone is complitly not turning on even when its in charger.
now all of my photos from my trip is didnt backed up what can i do now to restore all the photos and fix the phone?(the photos is very very important to me!)help :(
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @yehudashwartz
Check if the LDI (liquid damage indicator - click on the Liquid or corrosion evidence link) has changed colour, indicating whether water has penetrated the phone.
The impurities in the salt water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your phone and then remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives which may leave conductive residues and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes what happens. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the phone might possibly work correctly again.
Here is the ifixit Google Pixel 8 Pro repair guide that may help.
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Yehuda Shwartz さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 12
過去 30 日: 12
今までの合計 12
