Hp yang kemasukan air
Hp saya kemasukan air dan tidak bisa menyala
Hi @yamato2
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your phone and then remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives which may leave conductive residues and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes what happens. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the phone might possibly work correctly again.
Here is teardown video that may help.
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Hi
Kotoran dalam air menyebabkan korosi dan menyediakan jalur sirkuit listrik yang tidak sesuai dengan desain pengoperasian telepon dan dapat merusak komponen. Korosi dimulai segera dan berlanjut hingga benar-benar hilang
Pertama, jangan mencoba mengisi daya atau menghidupkan telepon Anda, lalu keluarkan baterai dari telepon sesegera mungkin untuk meminimalkan kerusakan lebih lanjut.
Kemudian Anda perlu membongkar sisa ponsel dan membersihkan semua bagian yang terkena dampak menggunakan Isopropyl Alcohol 99%+ (tersedia di toko komponen elektronik) untuk menghilangkan semua bekas korosi dan air. Jika memungkinkan jangan gunakan "alkohol gosok" karena dalam beberapa kasus ini hanya IPA 70% atau kurang, dapat mengandung bahan tambahan yang dapat meninggalkan residu konduktif dan tidak efektif. Jika Anda harus menggunakannya, periksa label untuk memverifikasi jumlah IPA. Semakin tinggi persentase IPA semakin baik
Berikut ini tautan yang menjelaskan apa yang terjadi. Electronics Water Damage (Kerusakan Air Elektronik)
Seperti biasa dengan barang elektronik, terutama PCB yang dipasang di permukaan, berhati-hatilah saat menangani dan terutama saat menghilangkan korosi. Anda tidak ingin menghapus komponen apa pun dari papan. Lepaskan pelindung yang mungkin menutupi beberapa komponen karena air mungkin masuk ke dalamnya. Ujung kabel fleksibel dan konektornya juga perlu dibersihkan Mudah-mudahan setelah Anda melakukan semua ini telepon dapat berfungsi kembali dengan benar.
Berikut ini pembongkaran video yang mungkin bisa membantu.
Jika proses ini tampak terlalu sulit, bawalah ponsel Anda ke layanan reparasi ponsel profesional yang bereputasi baik, berpengalaman dalam perbaikan kerusakan akibat cairan, dan mintalah penawaran untuk perbaikan. Jika Anda memutuskan untuk melakukan ini, lakukanlah secepatnya.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 6
