My Samsung A 51 over heating when charging
Why is my phone heated while charging, the charger also gets hot
@seantrim2008 the charger could be getting hot because your phone is drawing a higher amount of amps. For now you want to consider replacing the battery. A failed battery can be the cause of that. The only other thing you do want to take a look at is your charging board and the charging port flex. Make sure those are properly connected, show no corrosion or tears.
Here are the iFixit guides for that Samsung Galaxy A51 Battery Replacement
Samsung Galaxy A510F, remplacement du PCB USB, jack et boutons
ガイド
難易度:
中レベル
45 minutes - 2 hours
ガイド
難易度:
難しい
2 hours
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 80
