メインコンテンツにスキップ
PlayStationのアクセサリの修理とサポートページです。主にコントローラー用です。修理作業には通常のプラスネジ用ドライバとこじ開けツールが必要です。
966回答 すべてを表示
PS3 Guitar Controller 2d button releasing on its own, can it be fixed?
My son's PS3 Guitar Hero Controller's second button on the fretboard is not acting quite right. He presses it and it may work, or if he's holding the note it may simply release itself even though he's still got it pressed. Sometimes it says it's pressed when another button is pressed. Is there something I can do to fix it or will he just need another controller?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
4件の回答
ベストアンサー
The trouble is that this isn't a frequent problem nor is it a frequent product, however:
You could try opening up the guitar and checking the soldering/wiring of the button to the board. Loose connections could cause the button to act varyingly and a lot of 'it works sometimes' problems are due to it.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Just something to note... When I opened my controller I noticed that the plastic rocker triggers 2 steel switches, one for the up stroke and one for a down stroke, the plastic on the rocker switch had worn down where it is in contact with each switch, to a point where they were no longer pressing the switches correctly.
swiftly repaired with some superglue and a split matchstick.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
A good way to fix it is by taking the button off and blowing on the inside were the button i, because it could simply be that there is a lot of rubbish inside of it so it would be best to clean it out.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
i need some info on how to fix my ps3 wired controller any ideas
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
ELQ さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 2,361
